RCU Forums - View Single Post - modeltech twister
Old 08-05-2005 | 06:06 PM
  #79
kinverflyer
Default RE: modeltech twister
Where is your c of G? at 4 1/2" mine needs a bit of up elevator till its moving then feed it out and its fine, not a problem.
This is one airframe that would be spoiled with a big lump up the front. If you do feel the need then make sure you brace the back end and keep all the linkages tight and seal the control surfaces.
