RE: Ignition Timing Questions
If the module is preset to fire at about 4 degrees or so ATDC at startup (slow RPM), then when you initally set up the timing by turning the prop hub slowly, how does it know if your trying to set it up for full throttle at about 30 degree BTDC instead of just trying to start the engine?? What am I missing here??
