RCU Forums - View Single Post - Throttle return spring?
Old 08-05-2005 | 11:43 PM
excaliber
Default RE: Throttle return spring?
I don't remove or cut the springs on any of my engines for the simple reasons as RCign1 said to keep tension on the throttle plste and also if the throttle lingage should come off the spring will allow the throttle to go to idle. Wait till you have a lingage come off and the throttle plate does whatever it wants till you run out of fuel.
