RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 08-07-2005 | 10:55 AM
  #224
Ace-Maker
Default RE: gas fuel with glo plug no ignition
Is all of this really worth all of the trouble guys?
You still have to search for a special fuel
You have to mix it just right
You may have to keep your glo plug powered all the time
You might as well just give it up and run a spark plug and normal gas/oil mix
The whole idea of going to a gasser is to eliminate a lot of the unreliabilities of a glow engine
But if you guys are really that desperate to give this a go, well, hope you don't get too mad when you plant your motor 6" into the dirt cause it died on ya...
