ORIGINAL: Ace-Maker
But that is exactly my point...
Kind of - I don't see it
ORIGINAL: Ace-Maker
To me it would be a lot less hassle to balance my plane for the little bit of extra weight either a magneto or elec-ign would add... but thats just me...
Or you may try to think
bigger and tor that extra weight use bigger engine. In example somewhere around 40cc or 35cc on glow might weight the same as 25 with magneto. Extra power never hurts as long as you use throttle stick instead 'throttle switch'
ORIGINAL: Ace-Maker
I wouldn't risk putting something so unreliable on one of my planes...
I didn't find glow ignition on gas engine any less reliable than ignition-gas.
ORIGINAL: Ace-Maker
If you really want to run glo plugs why not just use regular glo-fuel in them? expense?
The main reason is the same, why we got a gas engine in the first place. Gas is just cool
. As long as the plane carrys on-board glow battery you work with this engine exactly the same field equipment as electronic ignition engine: Fuel the plane, flip the switch and flip the prop.
And the last thing is that the engine (my 25cc ) costs 25 dollars, when any decent size glow almost 10 times more.
ORIGINAL: Ace-Maker
If your in the hobby... spare no expense on your equipment... strive for the best...
If you are Bill Gates, not problem for spending a couple hundred dollars. But if you work for living, then the hobby gets what's left.[&:]
I would rather say, enjoy your hobby, not kill yourself with it.
RysiuM
