Best Prop Choice for this Engine and Plane !? ...
Hi Guys :
- I just changed the piston and sleeve of my 3 1/2 years old OS .46FX ... today i did the run inn of the engine (3 tanks of 12oz) and the engine is running strong as did before ...
- The thing is that im planning to put this powerplant on a Laser Models ARROW Delta Wing (its made for .25 to .60 size engines) ... SO .... i need to find the right prop for this plane (fast plane !!) ... i use to use this engine on a TowerHobbies Uproar before and was using an APC 12.25 x 3.75 prop ... i think the best prop for this delta wing could be a 10x8 apc prop ?, or its too little for the application that i want !? ....
thanks a lot in advance guys ...
PAT
