RCU Forums - View Single Post - when removing shims...
Old 08-07-2005 | 05:40 PM
smokingcrater
Default RE: when removing shims...
removing a shim increases compression, which in turn raises the heat and can cause pre-ignition, so you MAY need a cooler plug. depends on how close the engine/fuel combo was before you removed it though, there is no rule that says you have to change plugs...
