RCU Forums - View Single Post - Problem with braking
Old 08-07-2005 | 11:15 PM
bebopin64
Default RE: Problem with braking
alright this is the best i am able to explain this. on your carb there is a screw that you want. it is adjustable. it stops the carb from closing past a certain point cuting off the air. ig you adjust it to stop the carb to a point that it is open then you can press reverse on your remote and the spring will engage and your carb will stay open and your engine will continue to run.
