RE: Need a T500 engine expert.....
Turn, Thanks for the help, Ill try that all out!
Glow plugs Ive used MC9's, and anything comparable, once I toasted all those I went with everything I had in the flight box still with no luck, glow setting was 70 as it came from the factory yet still burned them. Gas setting was around 70 too if I remember correctly.. Ill check and reset them this evening maybe to figure it out.
Thanks so much!
