RCU Forums - View Single Post - engine surging and dies when the throttle is transitioning
Old 08-08-2005 | 11:58 AM
bruce88123
Default RE: engine surging and dies when the throttle is transitioning
It sounds like the idle mixture is tto rich. Try leaning it out slowly in 1/8 turn adjustments. Make sure to do this with the engine not running to keep your hands out of the prop. the idle misture screw is inside the rotating portion of the throttle barrel opposite the high speed needle.
