RE: Irvine 72
Patrick,
Yes I would be interested in the prop size you are running. A long stroke engine with a small prop would be vibration prone. The motor mount is two-piece but appeared to me mounted securely. Took the engine and motor mount out anyway and am in the process of adding triangular stock at the firewall and forward fuselage sides as a precaution.
Thanks.
Bill
