RCU Forums - View Single Post - Sword 2M pattern plane
Old 08-08-2005 | 07:49 PM
RC_Pattern_Flyer's Avatar
RC_Pattern_Flyer
Default RE: Sword 2M pattern plane
Inch. I have decided on the Mintor 170 with an aeroslave cf pipe. This pipe is short and smooth on the power curve, you may consider this for your application. I know Bob P. is using it on a OS 160 and others on an os 140 so it is quite versatile.
I am going to try and build all stock except for stap adjusters of some kind.
The mount i am going to use is the HYDE ARIA (sp) for the nose ring support. Otherwise, you might try rcaerobats.com i think.
This is where Bob P. built on his Aresti a nifty nose ring support.
As for the fuel tank setup. I am going to paint the canopy and cut a hole in the floor and strap the tank on the cg area.
More to come.. Chuck
Yes mine is here.
