RCU Forums - View Single Post - Are my calculations correct????
Old 08-09-2005 | 07:31 AM
gerwen's Avatar
gerwen
Default RE: Are my calculations correct????
the CV should be strong enough to pull both the stock gears and the BX gears (17t clutchbell, 56t spur)
You will get better acceleration with the stock gears, and higher top speed with the BX gears. If only swapping one gear, the clutch bell will have a much greater effect.
