RE: prop size?
Sorry thought your boat was a surface drive, actually if you go with a more powerful motor, usually you get more rpm even with the stock prop = faster boat. If you go with a matching size carbon fiber, or metal prop, even faster, because of less flex. As you go to a bigger prop, pay close attention to heat on, batts, wiring, ESC, & motor.
