RCU Forums - View Single Post - my first flight.... finally!
Old 08-09-2005 | 04:46 PM
bruce88123
Default RE: my first flight.... finally!
That's all good. Glad you finally got into the air. You still need to grind/file a flat on the nose leg or it will end up spinning on you again. Next time it could happen on takeoff and cause a wreck. Once you get your batteries charged up you can put the wall wart on a cheap timer so that it charges for an hour or two every day. This will keep them topped-off without over charging them. Be sure they are fully charged before putting on the timer. After a day of flying, charge overnight and put back on timer.
