RCU Forums - View Single Post - Sword 2M pattern plane
Old 08-09-2005 | 09:33 PM
PatternFlyer
My Feedback: (182)
Default RE: Sword 2M pattern plane
Ok, guys,
I have a couple more pictures here.
These are mostly for reference. The lines on the firewall is drawn as a datum line (center one).
If you add up the two lengths in the pictures, you will have around 34" without the stinger area. Subtract about .5 ~ .75" from that to have enough space to mount the cowl.
I am going with Mintor 140 I got used. Still thinking about the tuned pipe.
Well, I still have not contacted any of ES Design or Aeroslave for possibility of dealership.
I got my BlueBird 140 tuned pipe to test it with.
If the Mintor 140 is not enough, I will go with Webra 160.
I am also going to keep the kit as stock as possible, but the engine mount is a replacement. Gator adjusters are a must for the horizontal stab due to the factory mistake.
The picture of cowl may show the different curve right above the air inlet holes. The paint chips away really easy, so be careful.
I belive the two holes right next to the header tunnel are for the access of firewall, otherwise the two holes may not be a good idea since I may have to put RX pack behind the firewall.
It's building time!
More on this later.
Ihncheol Park
P & A Hobbies
[email protected]
ID:	308145   Click image for larger version
ID:	308146   Click image for larger version
ID:	308147   Click image for larger version
ID:	308148   Click image for larger version
ID:	308149   Click image for larger version
