RCU Forums - View Single Post - Minimizing control surface throw
Old 08-10-2005 | 11:36 AM
CGRetired's Avatar
CGRetired
Default RE: Minimizing control surface throw
You will loose a tad bit of resolution doing this, however, it is the only way, other than setting end points using the computer part of a computer radio. If precision is not an issue (pattern flying) then resolution is not such a big a deal.. however, the more you fly, the more you will begin to appreciate those finer adjustment points.
DS.
