RE: Just ordered a jerry's big boy
Howdy. I love my big boy with the G26. It is a bit heavy so I mounted the rudder servo in the rear and also put the battery back there. With a 16X8 APC prop it will not roll over ten feet before it's airborne. And even at $2.25 a gallon, it's a lot cheaper to fly. I'm using Hitec HS 475s on the wing, HS 635s for elevators, and HS 645 MG for the rudder. A 2000mah Nimh battery. This plane is really flies great and lands about as slow as you can walk. I used all the hardware that came with it. It was my first attempt at pull-pull and it wasn't hard at all. Here's a few pics of mine. You WILL NOT be disappointed, I promise.
