RE: CMP Zero Spinner Hub choice
Hi,
I'm still collecting all the various items needed to complete my CMP Zero. I have however already purchased the powerplant and spinner I will be using. I went with a Saito 150 which is probably a bit overkill, and I went to [link=http://www.skysharkrc.com/shop/index.php?shop=1&cat=15]SKYSHARKRC[/link] for a spinner I think will look the part pretty well. It's actually the FW190 A8 spinner, but the price was right, and I think it comes pretty close to the shape I was after. The D9 spinner is shaped pretty good too, but was concerned the 3.3 inch diameter was a bit too big. Skyshark has both 2 blade and 3 blade spinners as well.
What engine are you using? Do you have any mods or changes to the kit planned? I'm considering adding split flaps, but I'm not sure I want to cut into that pretty wing...
Hope this helps.
