RCU Forums - View Single Post - NEXSTAR ARF .....PROBLEMS...PROBLEMS
Old 08-10-2005 | 10:43 PM
  #75
bigtim
My Feedback: (13)
Default RE: NEXSTAR ARF .....PROBLEMS...PROBLEMS
rincloud was reading your post sounds like you need to file out the landing gear holes sometimes they get filled with paint or aren't drilled properly dont epoxy them in as you will have problems bending them back when you land hard" you will eventually land hard"my nextar has had some trials as mentioned in this post. but so far and after a rebuild after some (pilot error)flys solid." its about you flying your plane " if you dont have to adjust to some issues you are flying a kite as posted the front gear does have some issues. have your best engine guy at your club tune your engine sounds like she's running to rich factory settings foam the fuel rich sometimes do vibrate a bit. the nextar is a durable plane get your speed up and ease her into the sky good luck.BT
NEXTAR/U-CAN DO 46/TF-spitfire and some
