RE: Turbine alignment
And here another way of doing it. A woodblock turned in a lathe gives perfect alignment between my Merlin160 and Tam's pipe. Even the distance between the nozzle and exhaust is her adjusted to the correct value. It doesn´t matter if you are using a bifurcted- or a straight pipe, vertically and horizontal alignment is achieved.I´ve another block made for my P160.
My 2 cents.
Thomas
