RCU Forums - View Single Post - Does covering around the engine bay need special additional protection ?
Old 08-11-2005 | 04:57 AM
Phuzzy
Default Does covering around the engine bay need special additional protection ?
Hello all
My first kit, an LT-40 is almost done Busy covering it as you can see in the pic but I do have one question. I have fuel proofed everything that is needed before I started covering her. But can't help wondering if you have to give special attention to the covering around the outside of the engine bay area. Is merely iron on the covering sufficient to make it stick seeing that fuel, oil and heat etc. all could cause it to tear loose? What would the best way be to give that area additional protection if needed?
Marcel
