RCU Forums - View Single Post - Engine Cooling - Inlet & Exit
Old 08-11-2005 | 08:55 AM
Crusty's Avatar
Crusty
Default RE: Engine Cooling - Inlet & Exit
Good luck, Mustangs are a hard one to get right without it looking naff, make sure any ducting you use is very tight fitting around the cylinder(nearly touching the fins, dont use metal)
and make sure their is not an alternative easier route for the airflow to divert(it will always take the path of least resistance)
