ORIGINAL: Yann
Lt. Dan,
Godd idea, but how do you keep perpendicularity with your former, as you move it around to find the perfect spot ?
Also, you can only check two dimensions at a time...
Yann, I'm not sure I understand your question fully. I have measured the centerline of the airframe and then attached a string to run along it. I then line up the engine centerline along the string, and then once the mount is bolted in, I lined up the pipe the same way.
