RE: Airtech Bladerunner Help
Could be the battery is no good. Can you put a volt meter on it after charging it to see if it's charging?
Could also be the motors are getting too hot. If you are brave cut the canopy off and see if it flies longer without it, it's heavy and doesn't allow any airflow over the motors. Are all the blades intact? Even one blade bent or broken will not let it fly long.
