RE: .28 in a funfactor? oh dear....
What about modifiying the JT tower to bolt onto the CEN tower? That should give you the extra height that you need.
Try soldering up the splits and cracks in the pipe. If you use a high heat solder there should be no problem with leaks.
rolland
