RE: Engine placement/alignment????
....or you could build it with the correct thrust angle without any downwash and see how it flies. If you need corrections you could mix it in your radio. I can't remember if it is Andy Jesky or Jason Shulman who advises no firewall correction for torque/P factor, but use mixes instead. How much correction are you making for the engine to fit?
