RE: Warning to Evolution engine owners
....also check your vent lines for holes and cracks around the ends. Make sure the vent line isn't being shut off by rubbing the top of the tank. For a 2 stroke- check the fuel line running from the HS needle valve to the carb. Sometimes, you won't find the hole in the fuel tubing by looking or forcing air thru it under water. Swap glow plugs just to be sure if the problem remains.
