RCU Forums - View Single Post - BME-50, spark plug is bad??
Old 08-13-2005 | 09:33 AM
FalconWings's Avatar
FalconWings
My Feedback: (57)
Default BME-50, spark plug is bad??
Hi,
I can't get my BME-50 started, so I removed the spark plug, turned on the ignition and flip the propeller. I do feel a little shock when I turn the propeller, if I hold the plug by the threads, but I see no spark. It is obvious that the ignition is doing it's work cause I feel it. Is the spark plug supposed to visibly ignite?
Also, the sprk plug cable has a groung log, is it supposet to be attached to something? Does it make a difference? I don't think that the lug was attached to anything before, and the engine was running good.
David
