RE: arf planes covering peeling off
Never had much luck with clear nail polish.. Seems to turn yellowish and peel off after a short time.. If it is that Chinacote stuff good luck... Might try a little medium CA under the loose edges.. Use a little acetone to clean the exvess off... If you use an iron on the stuff usually it won't stay down and most like will "prune" up on you....
