ORIGINAL: the-plumber
ORIGINAL: aeajr
Is there a typo here. Looks like a bunch of 75 MHZ under the aircraft list.
No typo. The 75 MHz section specifically indicates _surface craft devices_.
I am not trying to be a pain, I am trying to understand your post. This is copied directly from the post. Note the whole string of, what appear to be 75 mhz channels, 75.xx listed in the middle of a series of 72.XX under airplanes.
CAn you clarify? If you doubt the list below, just go back and take a look at the original. I am just trying to understand what you posted.
From your post:
47CFR95.205 reads in part :
(2) The following channels may only
be used to operate a model aircraft device:
MHZ
72.01
72.03
72.05
72.07
72.09
72.11
72.13
72.15
72.17
72.19
72.21
72.23
72.25
72.27
72.29
72.31
72.33
72.35
72.37
72.39
72.41
72.43
72.45
72.47
72.49
72.51
72.53
72.55
72.57
72.59
72.61
72.63
72.65
72.67
72.69
72.71
72.73
72.75
72.77
72.79
72.81
72.83
72.85
75.41
75.43
75.45
75.47
75.49
75.51
75.53
75.55
75.57
75.59
75.61
75.63
75.65
75.67
75.69
72.87
72.89
72.91
72.93
72.95
72.97
72.99
(3) The following channels may only
be used to operate a model surface
craft devices:
MHZ
75
