RCU Forums - View Single Post - Bdavison's E-flite Blade Assembly
Old 08-13-2005 | 06:57 PM
  #69
Human_Enigma
Default RE: Bdavison's E-flite Blade Assembly
I would first suggest trying the same test with the servo linkages snapped off the swashplate ball links to make sure that the servo's are not trying to pull down farther than the rotor head will allow it against the center hub. If they dont jitter then lengthen the servo arms equally 1/2 turn at a time until the jittering stops. This in turn will change your pitch so this must be checked afterwards.
