RE: Bdavison's E-flite Blade Assembly
Human Enigma, Thanks for the quick response, unfortunatly I am stuck at work at the moment but when I get home I WILL be checking that. I never gave the head a thought. I greatly appreciate the feed back. One other question though. When setting up the swashplate by bdavison's method. The servos should be at the lowest point with the Tx in normal mode and the throttle lever all the way down when measuring the 1/2" from the top of the main shaft to the top of the swashplate, right? Thanks again for everything. Lovin this Heli stuff!!!!!
