RCU Forums - View Single Post - mounting on a cub scale wheel
Old 10-22-2002 | 10:40 PM
tailskid's Avatar
tailskid
My Feedback: (34)
Default DuBro Cub Wheels?
I'm sort of in the same bind - have a 1/5th scale Cub with 5/32" axles and the Du-bro wheel is 3/16" and yes, it is a tight fit!
I do what has worked in the past. Take an Allen Wrench and cut off the majority of the shorter 'arm' - just enough to get into the hex bolt ( that is holding the collar on).
Be sure you file a nice notch in the axle for the hex bolt to slide into :-) I also like to use a thread locker + some thin CA to make sure the collar stays where it is!!!
What kit/plane are you working on?
Jerry
