RE: Pull Pull Cable Crimps
Some cables will only pass thru the supplied ferrules twice- thru and back
not to worry - use ONLY nylon coated cables - Berkeley Steelon Leader is easily the most popular -
I crimp using Vice Grip pliers
you can imprint the cable thru a copper or thin steel ferrule.
Never had these slip -even using 2, 8611A servos
(80 lb test leader)
