ORIGINAL: kwaiweng
yup...i did put the schottky diode for the motor. I'm using 1N5819 (1 amp) as I can't get the 1N5822 here.
Hi Kwai Weng,
If you are using Mabuchi motor (RK370SD), below is the datasheet link:
http://www.mabuchi-motor.co.jp/cgi-b...AT_ID=rk_370sd
If I'm didn't remember wrongly, GWS300 or GWS350 is using RK370SD.
You can get 1N5822 easily in Sim Ling Tower (Singapore) or you can order through Farnell (Malaysia).
Below is the link, you guys might find it useful:
http://ww1.microchip.com/downloads/e...tes/00847a.pdf
(don't need to use the brakes)
Read PWM Issues (page 9) - 20khz/10khz/1khz
Keep Going! All the best!
