RE: Sig LT-40 Build
Looks good so far. This plane needs to have tringular stock added under the stabalizer for sufficient glue area and also from the stabalizer to the fin for the same reason. I normally add DuBro main gear (replacing the wire) and a Fults Double fork nose gear. The nose gear is important as the single forks have a tendency to bend in one direction. I have built several as club trainers and it is one of the very best available.
EXCAP232
