After having already built two KatanaS from the
’s plan:
i wanna show u my third one :
However this shock is a little different from those we are used to seeing on such forums. Besides it’s a control-line model. I guess it’s one of the first U-control Schock Flyer ever built. Letting u some pictures of the evelator control:
Handle and wire cable :
No electronic timer to switch off the motor. Just switch on before taking off and thanks to low-capacity NiCd Battery u can easily land when motor is losing its power. Don’t be affraid to put an important rudder flap angle so as to keep the plane out of the flying half sphere.
Eventually, even without the slightest knowledge about flying control line models, this one is so easy to fly that after a tiny minute u are able to do whatever u want whit it.
By clicking on the miniature u can see bigger pictures.
Technical conclusions:
Building: Depron 3mm + sheets of carboon tubes 3mm
Wingspan: 1,00m
Weight: 316 g
Motor: Speed 300 6V gearbox 1/5 (Mp Jet)
Airscrew: APC 10*4.7
Battery: 7elts 370 mAh NiCd
Wire cable: 2*12m kevlar fishing line or kite power line
Thus u can get an incredible flying model for less than 20$.
So let's try this new kind of experience and why not trying group flying ?!!!
