RCU Forums - View Single Post - Building a DraganFlyer - need to mix speedcontrollers - HELP
Old 08-14-2005 | 09:52 AM
  #2094
Spaceclam's Avatar
Spaceclam
Default RE: Building a DraganFlyer - need to mix speedcontrollers - HELP
i've also had the same experiance with the rudder. i've fond the best solution is to use rudder only as a trim, or for slow adjustments. afterall, other than to keep it straight, what do you need rudder for? this thing will fly in whatever direction you choose anyway...
