RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 08-14-2005 | 11:59 AM
  #484
Human_Enigma
Default RE: E-FLIGHT BLADE CP
does it want to Tip left, or Turn left? As far as the Daunting part, Welcome to the world of RC helicopters.. you can refer to your manual the blade came with, there is an exploded view of every single piece its made of and where it belongs. Piece (039) and (040) just need to be swapped in their position, both sides inside the blade grips. You will need 2 of the appropriate hex keys to get it apart, and it can be done while in the heli itself. Make sure you pay attention to the order of the washers that seperate the bearing and the o ring, after carefully removing the spindle you will need to hold it to get the other bolt loose, do this carefully with pliers and a rag protecting the spindle, or a vice making sure you dont bugger it up, squash it, or alter its shape and smoothness in any way shape or form. Then put it all back together with a medium grade loctite applying the loctite with the head of a pin so it doesnt gush all over everything. Then afterwards, reward yourself with a nice frosty beverage of your choosing..
