RCU Forums - View Single Post - need piston and sleeve
Old 08-15-2005 | 10:35 PM
rolland
Default RE: need piston and sleeve
www.ehobbies.com
www.toyhaus.com
I would suggest getting the .18 piston, sleeve, connecting rod, piston pin and turn it into an .18. I did this and it worked great and got several gallons out of it. Even if you just repalce the stock piston/sleeve you should also replace the connecting rod it is cheap 5$ insurance.
When you do put in a new piston and sleeve remember to set the carb back to factory settings and re break in the motor.
rolland
