RCU Forums - View Single Post - Landing help
Thread: Landing help
Old 08-16-2005 | 10:03 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Landing help
The methods mentioned work well. Since everyone is different, some methods work better for some than others, so with that in mind, here's another way of doing it...
First: As you make your turn to the base leg, note your distance and altitude. Starting right will help you get the right altitude and airspeed at the end.
Second: As you turn to final, glance at the surroundings. Notice where your plane is in reference to a landmark. Like, "ok, I'm just over that tree on the horizon". If you come in across the runway toward you, next time try turning just PAST that tree on the horizon.
