Engine Mounting
I applaude your decision to use socket head screws to mount your engine. Wise choice. It is not nessesary to use washers but it will give them a little more support. Lock washers are a good insurance if you are using nuts, however if you use self locking nuts as I do you don't really nead them. If you tap directly into the mount and use no nuts just a lock washer under the head will work.
