RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 08-16-2005 | 11:24 AM
  #239
av8tor1977's Avatar
av8tor1977
Default RE: gas fuel with glo plug no ignition
Guesses...
I don't think anyone else here is using the acetone. Could that be a problem?
Have you tried a different glow plug?
Maybe your engine has lower compression and will need some nitro?
Carb settings? Carb can't flow enough fuel without mods?
Did you run and verify this engine with normal ignition first? Run ok?
Good luck, and let us know,
AV8TOR
