ORIGINAL: britbrat
You still didn't tell us what it is --- how can we help with no real information?
What fuel? glow fuel, new
What prop? 10x9 I have been advised to by a 10x6 prop and will do that. instructor says it should help but not the dieing in flight problem.
Is it new, or old? brand new
Does it start properly? it starts, but could start better is it had a nose cone
Does it transition properly? what is properly?
Does it idle? yes
Does it blow fuel? only when flooded
Was it in a serious crash? no
Did you ever dissassemble it? nope
How was the idle mixture set? set rich enough to get it to start easily.
How was the high speed mixture set? according to the manuall 2 1/2 turns from all the way shut.
How is the tank pressurized? there is a hose going from tank to muffler i supose that pressurizes it.
Have you checked for loose head bolts & back-plate bolts? on the engine, no
Have you checked for an air leak. air leek where? at the base of teh carb? I tighten it down every time I go out.
Shutting off in flight at full throttle usually indicates --- fuel starvation from a problem in the delivery plumbing, or too lean a fuel mixture, or overheating from a variety of reasons.
Not many choices -- these engines are very simple, so it is findable & fixable (don't discount bad tuning yet).
fuel tank was full when it took off. it was up for about 5 min. at full throttle doing lazy circles around the field. I attempted 3 inside loops and accomplished 2 the 3rd fell through, not enough power, other than that it was just going from one end to the other and back again.
