RCU Forums - View Single Post - Need to increase acceleration help!!!!!
Old 08-17-2005 | 09:05 AM
plaidfish
Default RE: Need to increase acceleration help!!!!!
is your top speed fine? what is the buggy doing when you punch it? if it sounds like it's got a low rumbling noise then takes off it's too rich....If it sounds like it just gets weaker the more you pull the trigger but then starts screaming and dies it's too lean.....seems as though you're too rich on the bottom (LSN)....turn it in just a crack at a time......I'd also richen your HSN before you get to the LSN...if you're running at 250 now you'll be hotter overall when you lean out the LSN.......
