RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 08-17-2005 | 08:42 PM
  #250
aero nut
Default RE: gas fuel with glo plug no ignition
"DO NOT USE ACETONE" It swells the carb components and it makes the engine boggle tried it and didn't like it. just stick to the methanol/gasoline blend but if you can add Nitromethane it would make your effort worth a lot, you will see how well it improves performance, keep up the work we are learning a lot.
