RCU Forums - View Single Post - G3 Remote not working
Old 08-17-2005 | 10:23 PM
rjm1982's Avatar
rjm1982
Default RE: G3 Remote not working
try different USB ports...dell uses cheap motherboards and not all of the usb ports (if any) provide the Voltage that they should...there is a fix however...you can get a POWERED usb hub for around 10 bux online, or 20 in a store...thats probably the problem...though dell has gotten better, this is something that they still do (mine at work, the front usb port is powered, the 3 on the back are not..)
