RCU Forums - View Single Post - help me program my tx
Old 08-17-2005 | 11:35 PM
richohealey's Avatar
richohealey
Default RE: help me program my tx
mmm that's interesting jooNorway. some of my planes i fly around on high rates the whole flight and only have low so that dad doesn't freak out when he flys them. but with my foamy, (it's the most aerobatic model i have for now), low rates are a must when landing etc. at 45 deg travel on everything it takes one reflex push to the edge to un-roll if the wings catch the wind to roll it into the ground VERY fast. like your style though. one thing i should point out, test your expo before you fly, different radios use positive or negative to soften, the other way to harden them (bad). also think about whether you should have all the surfaces on one switch ofr seperate. liek on my sportster, i have 3 switches, so that i can have low aileron and still high rudder and elevator if i want it for some manouvers. but my foamy i need to be able to switch from 3d to normal very quickly, and so have them all on one switch, because if i fumble down low, it's all over.
hope this helps
-richo
