RCU Forums - View Single Post - Sig LT-40 Build (maiden a success!!)
Old 08-18-2005 | 06:50 AM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Sig LT-40 Build
Somegeek,
I too came away from reading your post thinking that you joined the wing halves with CA. If this is the case you need to stop and fix this. The wing halves need to be joined with 30 minute epoxy. If not the wing halves will most likely separate during flight. This is a very high stress joint and you need the strength of epoxy to hold it together.
Hope this helps
Ken
